12volt tv (1 Viewer)
TheBig1
17,630
43,271
5amps per hour, so if youre only operating the tv expect 50hours use from a 100ah battery before it needs charging. obviously you will also use lights and pump etc so somewhat less. but you dont watch a tv night and day normally
in practice we can go 6 or 7 days without recharging but using tv fr a few hours only each day
lunarman
2,156
2,451
South Glos
since 1994
I'm sure the big1 meant 20hrs (100/5=20) However I beleive that you will only get 50% of a batteries capacity so effectively you will only get 10hrs.
Lunarman
TheBig1
17,630
43,271
youre absolutely right, not sure where the 5 got there from, probably because its directly above the 2 on the keypad. personally i recon it was a brain fart:ROFLMAO:
oh shit, im getting old:whatthe:
Nov 6, 2013
1,416
3,169
S. Ayrshire
The usual
Since the beginning
60W sounds a little on the high side for a 17in telly.
Just checked the power consumption of our 16in tv, and it's 13W
43,329
49,441
does the tv have an inbuilt dvd player ?
If so the 60watt rating will be when using the player which would be around 5amps.
The tv itself would be nearer to 20watts max or just under 2amps
