12volt electics swift kontki 669
Discussion in 'Swift Motorhomes' started by Family Guy, Feb 7, 2009.
  1. Family Guy
    Family Guy Funster
    Nov 20, 2007
    264
    202
    runcorn
    When I. Start engine all habitaction and any 12 volt accessories turn off is this normal if so can I change it to run with 12 on
  2. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,349
    5,361
    East Sussex 01-580-881288
    Think you will find its normal and complies with some Road Traffic Act somewhere!
    I could be wrong.
    Peter
  3. sinbad1
    sinbad1 Deleted User
    Same on the auto trail although fridge only works on 12v when engine started.
  4. Family Guy
    Family Guy Funster
    Nov 20, 2007
    264
    202
    runcorn
    Hope not never had it on my yank or the last 4 german vans also have to find somewhere to put the spare wheel
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,946
    17,612
    YO11 2BD
    it could be changed by taking the cutout relay out of circuit but why would you want to ?
    it does it for a reason and i think the reason is the voltages produced from the alternator CAN be a lot higher (15/16v at times) than some equipment can tolerate.
    your fridge is just a heating element so can withstand the higher voltages, within reason but if the hab 12v control panel /heater/boiler has a PCB it WILL blow it.
  6. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,569
    3,376
    Telford, Shropshire
    Its done on UK built motorhomes to remove the possibilty of electro magnetic interference affecting safety critical systems such as ABS, engine management etc. In truth it is not necessary, evidenced by almost no mainland European motorhome manufacturer bothering about it. There is no legislation that requires it to be done this way, either road traffic or otherwise but I think there is some sort of directive somewhere.
    D.
  7. hilldweller
    Dec 5, 2008
    27,246
    26,243
    Macclesfield
    You are. It's a peculiar UK manufacturers thing, some UK Caravan Council.
    No doubt laughed at across Europe and by us in our Burstner.
  8. Family Guy
    Family Guy Funster
    Nov 20, 2007
    264
    202
    runcorn
    What do I need to do to run my interior lights and tv in the back of the van so the kids can watch a DVD on the move or any company near runcorn Cheshire to sort for me
  9. hilldweller
    Dec 5, 2008
    27,246
    26,243
    Macclesfield
    This thread has been done once or twice on MHF. It involves removing a single wire that senses the ignition is on, but I don't know which wire.
    There was an "engineer" on MHF who always said "it's because of EMC regulations" so being 99.99% sure it wasn't I always asked "Can you quote which one". He never did.
    Basically the EMC regulations which run to thousands of pages say "your product must not emit electrical radiation that interferes with other equipment and your product should reject interference". It's belt and braces, in theory you don't need both halves.
    You will recall the same panic in hospitals, covered by the same EMC regs. Strange that at the same time mega expensive phones were installed on the wards. Now, all of a sudden phones can be used in hospitals.
    Unfortunately I can think of one tiny gotcha, if something fell over on the move, shorted a 12V wire and caused a fire ( now that is tiny ) what would your insurers do ?
  10. hilldweller
    Dec 5, 2008
    27,246
    26,243
    Macclesfield
    Type:
    habitation power the NCC (National Caravan Council) approval scheme
    into Google and see what you get :)
  11. Family Guy
    Family Guy Funster
    Nov 20, 2007
    264
    202
    runcorn
    does any one know what wire or relay i need to disconnect to run my 12v habitation on the move as dont want to put a new feed in for tvs lights etc
  12. sinbad1
    Sorry cant help with the wire bit ;but why not make a separate circuit to include tv/light direct from the habitation battery( make sure ther is a suitable fuse).:BigGrin:
    Regards
  13. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,737
    5,967
    Mansfield,Notts
    I was under the impression that the power cut of was to prevent use of the heating system on the move
    Other EU countrys allow heating on the move, and heaters had to be certified as safe to do that, here in the UK for whatever reason in the majority of cases there not:RollEyes:
    Geo
  14. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,349
    5,361
    Hi,
    Had a word with Glenn our service manager and he does not recommend a DIY job, it is not a simple matter of removing a wire or relay, it is a rewire jobby and one has to be careful as the control panel doe not like it! Could cause a spike and blow it.
    If you want to know more, your welcome to give him a call
    Regards
    Peter
  15. Family Guy
    Family Guy Funster
    Nov 20, 2007
    264
    202
    runcorn
    thanks Pete for the life of me cant understand why its wired this way if a european van doest req it why do British vans whilst traveling kids like tv on lights on to draw etc don't want a diy job new van first British van so far very impressed apart from silly wiring
    many thanks
  16. SwiftGroup
    SwiftGroup Read Only Funster
    Jan 10, 2008
    108
    The EMC regulation (Electromagnetic compatability) is a european standard and a european directive which all touring caravan and motorhome manufacturers have to comply with. This applies across europe including France and Germany, any manufacturer that chooses not to comply does so at their own risk. This standard was published in 2000. All Swift Group products comply with this standard.
    This standard is designed to isolate appliances and circuits to prevent any potential interference with the base vehicle and its components. Only the fridge, en-heater and some lighting components are homolgated to the EMC regulation.
    Regards
    Andy
  17. david price
    david price Read Only Funster
    Sep 28, 2008
    387
    27
    Bridgenorth
    Wireing
    Hi,i have a bessie e769.
    The light above the hab door does work while travelling,has does the blown heating and water heater.
    For the rear tv to work i wired a couple of 12v sockets direct to hab battery with an inline fuse.I ran wires along the overhead lockers and behind control panel,then through to microwave cupboard .fitted socket under microwave in a little recess,very neat & you would never know it was there.
    Got all the bits from halfords,fairly easy to do and approx 1 to 2 hours.
    Dave
  18. pappajohn
    Aug 26, 2007
    29,946
    17,612
    YO11 2BD
    exactly what i said in a previous post :thumb:
    straight from the horses mouth, so to speak.
    if the convertors do it ,it must be for a reason. :Doh:
  19. Family Guy
    Family Guy Funster
    Nov 20, 2007
    264
    202
    runcorn
    Thanks I think the best thing to do is just wire tv and a light seperate that way keep warranty apart from that happy with it
  20. hilldweller
    Dec 5, 2008
    27,246
    26,243
    Macclesfield
    Rubbish.
    CE marking is not optional. If any goods are put into service not complying with all the appropriate regulations they would jump on the manufacturers from a great height.
    Add to that, a German would rather pickle his own testes in concentrated sulphuric acid than not comply with the regulations.
