12v troubles in soggy France (1 Viewer)
bhs
214
137
Louth
b class
since 2006
Hoping someone may have translation/inspiration regarding fuses in Electroblock EBL 104-3
1999 Hymer
After travelling for several hours in rain we parked up (on EHU) lights on, boiler on, fridge on mains, after about half an hour lost 12volts, mains still on, started engine 12 volts restored temporarily, fiddled about in dark, turned everything off except 1 light waited til morning. Turned things on 1 at a time, fuse from leisure battery feed blew, 30 amp, took all fuses out of electroblock, replaced 30 a battery fuse, introduced other fuses 1 at a time, upshot is if I fit 25 amp fuse marked Grundlicht Trittstufe (step) 30 a leisure battery fuse blows, if I fit 15 amp fuse marked ABS-KS ohne Aes panel shows a constant 10 amp drain
Any ideas would be appreciated, the meaning of ABS-KS ohne AES would be very helpful
verywet in Brittany if I can sort this glitch will head south very soon!
thanks
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
the step pivots are coated with gunge and crud, dismantle, clean and reassemble bolts WITHOUT oiling. the step should then work normally without drawing excessive power.
Feb 24, 2013
13,083
101,446
Bolsover, Derbyshire
Hymer S800
not long enough
feel for you, you have my kind of luck, can't really help with the translation but the AES could possibly be the fridge presuming you have auto energy selection on yours and the draw of 10A would be typical for a fridge on 12V maybe
I wish you the very best of luck and hope you get sorted and continue (y)
bhs
bhs
214
137
Louth
b class
since 2006
Yes I need the aes translation, had thought of the fridge it is not auto, the 12v selection switch makes no difference to current draw, fridge should only work on 12v with engine running, am aware relay may be stuck, don, t want to go down that road until I know that the fuse marked ABS-KS ohne AES actually relates to fridge supply
Can live without the step for the time being,
still raining!
bhs
bhs
214
137
Louth
b class
since 2006
Could it be that AES may be an abbreviation for Absorption
and Kuhlschr an abbreviation for the german word for fridge?
and ohne AES means without AES
just leaves the questions what is AES stand for, where is fridge relay?
still raing, this little tablet is driving me mad?
bhs
bhs
214
137
Louth
b class
since 2006
to simplify fridge 12v circuit draws 10 amps when switched off (shows on control panel in MH) why might that be?
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
could be the relay is short circuit. run fridge on gas and remove the offending fuse until you have located and replaced the relay
simbadog
1,683
3,337
Wengen
A/S Broadway EL 2021
Since 2010
ABS-KS might well be a float level switch? ohne AES means without AES.
filopastry
1,016
1,738
london
littleun
newbie and learning every day
Found a Dutch posting that suggests that maybe a "mass" earthing problem caused a problem which seemed related between his steps and fridge try adding a sure earth direct to the fridge as seen if a poor earth exists strange things happen, turn on indicators and wipers/brake lights etc can illuminate as power finds the easiest return to earth.
http://www.camperforum.nl/viewtopic.php?f=3&t=8451530&start=0
filopastry
1,016
1,738
london
littleun
Have you by chance "twiddled" with "any" unrelated wiring or disturbed any recently ??
bhs
bhs
214
137
Louth
b class
since 2006
Pulled the two fuses mentioned and can continue journey with interior lights, pumped and heated water, flushing loo. Have lost water level indications, step, leisure battery status indication and I think 12v fridge operation.
when the sun shines will check existing wiring I did clean out behind fridge, will re earth fridge too, thanks everyone
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
It's you that's bringing the rain here then is it? Where in Brittany are you? Your welcome to park up on our driveway and get it sorted if it helps?
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
AES is the fuse for an Automatic Energy Selection fridge - Kühlschrank is German for fridge. On the later EBL99 / 100 models it is marked "Kompr. / AES Kühlschrank" for either Compressor or AES fridges.
Scattycat
920
1,262
Mayenne, France
Rapido
Since 2010
1999 Hymer
thanks
It'll be nice tomorrow, loads'a sunshine . . . . . Apparently
