12v parallel pin to USB adaptor (1 Viewer)
Jan 2, 2015
2,470
8,624
Cumbria
Burstner Solano t725
since 2014
I have a female socket on the MH that one of these fits.
Does anyone know if you can buy the male two pin plug on its own with USB port(s) built in? I currently fit a cigar lighter /USB adaptor into the end to charge the phones.
D
Deleted member 29692
Google usb 2 pin plug and you will find plenty.
Puddleduck
12,385
43,987
Scottish Borders
Without at present
On and off for many years.
Is this the sort of thing?
Broken Link Removed
or this:
Broken Link Removed
tonka
10,829
21,524
Cannock, Staffs
A class Burstner 800
Since 2000
I am going to stick my neck out and say a 100% NO...
That 2 pins 12 socket / plug is years old design and the USB so much newer. No one would ever manufacture something for such a small demand....
43,319
49,389
I doubt very much you will find the plug you seek.
not enough demand to be worthwhile the trouble designing and making moulds etc.
namwaldog
Jan 2, 2015
2,470
8,624
Cumbria
since 2014
The male socket on its own looks like this....
perhaps there is one with the USB sockets in the back. I agree with your point Tonka but someone may have seen one somewhere.
43,319
49,389
I just fitted one of these in my car for phone and tablet charging.
Only requires a 26mm hole and a live feed from an existing circuit.
The square bezel and cover can be removed so it becomes a round fitting.
Broken Link Removed
namwaldog
Jan 2, 2015
2,470
8,624
Cumbria
since 2014
Thanks NickNic. It looks like the two flat pins are the same size whereas the one I need has a broad pin and a narrow one.
Thanks for all your fast replies I think that a new female socket such as pappajohn & tonka recommend is probably the way forward.
Puddleduck
12,385
43,987
Scottish Borders
Without at present
Badknee
7,407
412,527
notloB
Vantage Neo
Living the dream.
Do like we do and go twin plug to ciggy lighter socket and stick a ciggy plug to USB socket in it. Works great.:D
D
deleted-member02
Broken Link Removed
I installed one of these after removing the aux power socket from the centre console, couldn't of been easier and looks factory fitted (y)
Next job is to remove the antiquated Hella socket and replace with one of these
Broken Link Removed
Some great solutions on Ebay
GJH
29,450
38,827
None, now sold
2006 to 2022
We had a socket like that in our Autoquest. I took the cigar plug off a multi-socket adapter and replaced it with a 2 pin plug like the one in your photo, remembering that the positive on a cigar socket is the end terminal and the negative is the side clips. As with any electrical circuit the trick is not to overload its capacity.
Our Burstner has Hella sockets so I did the same sort of thing with a Hella plug.
Lenny HB
53,404
149,851
On the coast in West Sussex
Hymer B678 DL
That is a 2pin American plug made by Australian company Clipsal, they were used in UK caravans in the 80's for 12V.
You could buy Broken Link Removed and connect it to your plug.
