12v heaters?
Discussion in 'Tech/Mech General' started by tommytli, Dec 14, 2009.
  1. tommytli
    tommytli Funster
    May 26, 2009
    443
    26
    lancashire
    can any 1 recommend a 12 v heater? we are setting off to disney friday and just want 1 to keep every one warm in the back whilst driving down. our m/h just has gas blow air heating so i cant run that whilst driving so can any1 tell me of a good little 12v one please.
    i have see these but cant imagine them to be very good or am i wrong?
  2. DESCO
    DESCO Read Only Funster
    Mar 11, 2009
    2,651
    267
    London
    To be honest I have never yet found a 12v heater that did any more than use electricity and nothing else.
    A typical 12v hair dryer is an example you would be better off sitting near a hot cup of tea, or just plain blowing. As the OH says they are as good as a chocolate fire-guard.
    Dave:thumb::thumb:
  3. johnsandywhite
    johnsandywhite Read Only Funster
    Jul 29, 2007
    2,348
    15
    Doncaster/Spain
    :Cool: I agree with Dave. I have 2 of these 12 volt heaters. You get MORE heat from a 12 volt kettle and THAT is NOT saying much either. :Rofl1:
  4. tommytli
    tommytli Funster
    May 26, 2009
    443
    26
    lancashire
    thanks guys i thought as much:thumb:
  5. ginge61
    ginge61 Read Only Funster
    Oct 29, 2007
    431
    n/wales
    run the blown air ??
  6. scotjimland
    Jul 25, 2007
    28,976
    25,674
    why not ?
    We run our's if it's needed.. as already said don't waste money on a 12v nail varnish dryer
    jim
  7. tommytli
    tommytli Funster
    May 26, 2009
    443
    26
    lancashire
    is it possible when driving? wont the pilot light be blown out?
  8. tommytli
    tommytli Funster
    May 26, 2009
    443
    26
    lancashire
    is it possible to drive with the blow air heating on gas?
  9. phil1946
    phil1946 Funster
    Apr 21, 2009
    272
    3,635
    South coast of England
    Running Gas Blown Heating whilst travelling
    Hi,
    I can only say that it works fine on my Hymer and never causes any problems - not sure about legality and MUST turn off before fuelling or going on a ferry!
    Oooh but it is nice to be warm in a large box that sure defeats the cab heater.
    Best wishes to all for the forthcoming festivities.
    If it don't do good - don't do it!
  10. Macytia
    Macytia Read Only Funster
    Nov 30, 2009
    66
    North Wales
    I run my Eber whilst travelling if need be, ableit its not gas:Laughing:
  11. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,320
    17,030
    Liverpool.
    Hi, dont know about European campers,but we run our heating in the RV when its cold when traveling.
    We also run the genny going down the road if we need extra aircon and for the locker freezer.
  12. tommytli
    tommytli Funster
    May 26, 2009
    443
    26
    lancashire
    might give it a try then just worried about pilot light going out and getting a gas leak or summat along them lines
  13. Spacerunner
    Spacerunner Read Only Funster
    Apr 7, 2008
    609
    195
    Hampshire
    If you have a modern boiler you'll most probaly find it doesn't have a pilot light. It will work from a Piezo igniter when the main burner needs to come on.
    Also if it does have a pilot flame then there should be a flame failure device which will cut off the gas supply to the pilot light.
    My X2/50 has a good idea. The engine's hot water system has been extended to under the driver's seat. So when we need heating in the habitation area there is an extra fan switch on the dashboard that blows through this heater matrix and pushes the heated air to the rear.
    Works really well, we have to turn it off after 15 minutes as the dog is starting to puff and pant :Smile:
  14. tommytli
    tommytli Funster
    May 26, 2009
    443
    26
    lancashire
    my m/h is an 08 so i might be ok, i will give it a go for a few miles then check its ok. thanks again every 1
  15. ourcampersbeentrashed
    ourcampersbeentrashed Funster
    Apr 19, 2008
    7,652
    4,284
    East London
    Give your passengers blankets and regular TEA stops - far less expensive
    Heaters only make you more cold when you open your back door xxxxx
    Hope you have a safe one as heavy snow is forecast xxxxxxxxxx
  16. sakura881220
    sakura881220 Read Only Funster
    Jan 14, 2010
  17. derekfaeberwick
    derekfaeberwick Read Only Funster
    Dec 1, 2007
    1,131
    8
    Berwick
    DON'T OPEN THE PREVIOUS POST. I've reported it.
