12v HD Freesat (1 Viewer)
S
stagman
From Argos incase someone might be interested but you will need to get your own 12v dc lead . . :thumb:
scotjimland
2,231
9,714
A Woosh bang
Maybe I'm missing something on the product info, but where do you see that it can be used on 12V DC ?
scotjimland
2,231
9,714
A Woosh bang
here you go Jim.....right hand side of rear panel image.
cheers John.. never looked at the images.. :Doh:
they should put that info on the product info for us dummies :roflmto:
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
I have that very one. Good price! When I bought mine at 69.99 there it was 99.99 at Maplins
Jul 4, 2010
1,194
804
Essex / central France
Hymer Star Line 680
9 years
Looks like a good deal, but does anyone have experience with this decoder in particular on the move (ease of setting up regularly)?
Just a dim second question, is it only 12v powered as can't see another 230v connection point.
Techno
Jul 28, 2010
15,475
20,756
May 2010
It is 12volts via a supplied 230volt transformer. On the move? once you set it up that's it. Astra dont move (much) :roflmto:
Jul 4, 2010
1,194
804
Hymer Star Line 680
9 years
Ah ha, those Bush people are quite cunning. Didn't see whether the transformer came with it or not, don't think it was demonstrated in that interesting video either?
Going to dig a hole for myself here... nope, wont ask an even sillier question.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Maybe a picture will help? Mine is velcro'd to the wall and the remote works by pointing it at the ceiling. The power supply is in the plug nearest
tonka
10,821
21,507
Cannock, Staffs
A class Burstner 800
Since 2000
Thanks for the info..
Guess where i'm off to tomorrow..
I need a new receiver for the van, coming next week..:thumb:
Need to decide on my sat dish / dome now... Decisions - Decisions....
Jul 4, 2010
1,194
804
Hymer Star Line 680
9 years
Oh dear... your power supply is 230v into the tranformer? If so will a direct 12v supply work too?
Sorry
Techno
Jul 28, 2010
15,475
20,756
May 2010
Yes I use both. Sometimes I need the 230 socket for something else and I use a 12 volt lead into either of the 2 12 volt skts
Techno
Jul 28, 2010
15,475
20,756
May 2010
Bear in mind that you need a tv with an HDMI input to receive HD.
Connection via scart will work in SD only
freelanderuk
1,018
534
Saltfleet/Lincolnshire
c class
i have one of these for sale , they are very good and also have a sat finder type of display in the channel info menu , only selling as bought a 12v tv with sat and freeview receivers built in
Scout
3,957
120,762
South Yorkshire
chic c line
12 years motorhoming, a lifetime of living
2 things come to my mind
1: if you are using the 12 volt in by any other power sorce than the transformer, should you use a 12 volt stabalizer to ioen out any flucuations in the power supply?
2: would a better unit be one with a recorder so you have something to whatch on the days your parked near a big tree and xant get any satalite to lock on? even if you need to run one through a inverter to get power
Scout
3,957
120,762
South Yorkshire
chic c line
i never used the 12v stabilizer with mine or the tv and never had any problems
is that a a tv or receiver? i hope its the tv because my tv has got got an external 240>12 volt tranformer and was under the impression I wouold need to stablaize a 12volt source if I wire it the leisure battery 12 volt line.
scotjimland
2,231
9,714
A Woosh bang
There is no purer source of DC than a battery, the DC from a cheap 230V AC - 12v DC is very rough ... ie it isn't a smooth DC. it is rectified AC.
The voltage from your leisure battery when fully charged is 12.6v .. and when 12v, effectively flat. (go below 12v and you shorten the life of the battery) This is well within tolerance of a 12VDc TV or Tuner ..
There is however a small risk when charging (ie on EHU) as the voltage can be as high as 14.4v .. hence the reason some advocate a 12v stabiliser .. but if you are concerned it is cheaper just to plug the TV into the mains socket with the supplied adaptor..
I have used both TV and Tuner on 12v with no stabiliser .. with no detriment to the kit..
S
stagman
I have used both TV and Tuner on 12v with no stabiliser .. with no detriment to the kit..[/QUOTE]
Same here never had any problems :thumb:
freelanderuk
1,018
534
c class
the 3 12v tv's i have had and the 12v sat receivers have all been used with no stabilizer whether on just battery or 12v and ehu with the charger running, the tv i have now can run on anything from 12v to 25v or 240v
