12v Electrical Question, any sparkies on here? (1 Viewer)
paulweller84
19
Southampton
I'm a newbie
Hi, I would like to install a main switch by the main door on my van so I can switch everything on or off when entering or leaving, this would mean running a switch cable from the main control panel, but my question is what size of cable should I use? I could use something decent sized to remove any doubt about capacity but it needs to be as small as possible to make it easier to route through the van.
Aug 6, 2013
11,953
16,567
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
The simple way is to use a relay. That way you have no cable losses & can use very thin wire to your switch. I can send you a drawing if you wish & it really is very easy to do.
P
paulweller84
19
Southampton
I'm a newbie
Thanks, I'm assuming I would need to fit the relay just before the main supply enters the control panel, then run a switch wire over to the new switch. Would I be right in thinking the switch would also need a permanent live feed? If so I think running from the cab interior light would be easiest
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
Make sure you don't switch off any charging arrangements , solar etc.:whatthe:
TheBig1
17,613
43,147
Running a trigger wire from the light circuit wont work as the power would be off if the relay is not energised. you will need to run 2 wires to the switch, a live feed and a trigger return to energise the relay
very simple to do, but there will be a constant drain when the electrics are on because the relay will take power. plus its another potential point of failure as with any moving part
Aug 6, 2013
11,953
16,567
Kendal, Cumbria
since 1999
You would be better finding the main output & fitting it there. I don't know what sort of control panel you have but most allow you to choose either leisure or start battery to feed the 12v system via a selection switch. The wire from that switch that heads off to the fuses/switches on the panel would be where I'd choose to place a switch or relay. Depending on your panel that may not be easy so your method would work with the proviso noted in the last post re charging etc.
The best place to take your relay operating supply from would be the wire you break with the relay (before the break of course!).
Aug 6, 2013
11,953
16,567
Kendal, Cumbria
since 1999
See attachment.
Tmesis
29
10
Surrey
4 years
Have you considered things that need to stay on? Fridge electrics, radio, alde boiler, anything that needs a battery for its memory. Presumably if you have a control panel, it will have a ethos of its own to isolate consumers?
What control panel and 12v distribution system do you have?
P
paulweller84
19
Southampton
I'm a newbie
My idea is to power the switch directly from the leisure battery so when it's open it doesn't draw power. Then when it's switched on it powers the relay and only uses battery power when the leisure battery is powering everything else. If that makes sense? Would that work?
Also, does anyone know how to bypass the system that cuts off the power when the ignition is turned on? I'd like the option of running the engine to charge the batteries while we are using the van. At the moment all the power goes off which is quite annoying
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
I have to admit to being slightly at a loss to understand why you want to do this. I assume you are talking about a master switch for the 12V habitation systems? Our van has a master 12V switch in the control panel above the habitation door, but I generally switch it on when we set off somewhere and switch it off when we get back. So far, the longest elapsed time between those two events is six weeks. I cannot think why I would want to switch it off.
I realise my motorhome might be wired differently to yours, but the 12V master switch described above does not affect the step, entry light or Truma temperature safety valve; these stay on regardless.
To isolate all 12V habitation circuits in my van (including the last three above) one has to switch off the main switch on the main charging system which is under the driver's seat. I only switch that off if changing batteries or carrying out any cabling work.
Aug 6, 2013
11,953
16,567
Kendal, Cumbria
since 1999
Relay current drain would be of the order of 80mA & as you suggest only when domestic power is switched on so not important. JeanLuc's system is exactly the same as mine (mine is Hymer B584). It would be useful to know a little more about your control panel (make & model & any other info you have) to answer your second question - and would enable a better answer to your first.
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
all the power going off doesnt stop the charging of the leisure batteries.
