12v Cab Socket not working
Discussion in 'Tech/Mech General' started by Dogsense, Nov 9, 2014.
  1. Dogsense
    Dogsense Funster
    May 5, 2014
    420
    112
    Leicestershire
    Help Please from all you cleaver Funsters.
    Fiat Ducato 2012, 12v Cab Power Socket (not the cigar lighter) stopped working,.
    Checked 15A Fuse and it's OK. What else can be the problem?
  2. peter marshall
    peter marshall
    Mar 5, 2009
    2,702
    1,701
    Cleveleys,Lancashire
    A loose wire or replace the fuse again sometimes look ok but have blown, test the fuse with a meter. Pete
  3. Dogsense
    Dogsense Funster
    May 5, 2014
    420
    112
    Leicestershire
    Thanks Peter, I swopped fuses but still no power in the socket.
  4. hilldweller
    Dec 5, 2008
    27,559
    26,672
    Macclesfield
    Are you 100% sure of it being the right fuse ? Check all fuses.
  5. Badknee
    Badknee Funster
    Aug 25, 2014
    3,791
    16,828
    notloB
    How are you testing the socket? If you are plugging something in it may be the fuse in the plug, it will have one, test with a meter to a good earth. :)
  6. CWH
    CWH Funster Life Member
    Jan 29, 2014
    3,112
    13,596
    under a wand'rin' star
    Sorry, can't help, but can sympathise - we blew all 4 12 amp sockets in the MH (rogue satnav) & it's a real sod getting at the fuse box under the hood for the ones in the cab!
  7. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,188
    15,163
    Leeds the one up North
    Where does your manual say the fuse is?
    On my 2008 both sockets are on fuse 44 20amp, fuse box in cab drivers side
  8. Techno
    Jul 28, 2010
    14,188
    15,163
    Google tells me that yes it is the engine compartment fuse box
    F14 should be 15A and F15 10A. Power and cig socket respectively.
  9. Mattyjwr
    Mattyjwr Funster Life Member
    Aug 18, 2013
    1,913
    3,358
    Beds
    Do you have a circuit breaker on your van? We've tripped ours when moving items in the cupboard where it is located and lost 12v power to a couple of sockets.
  10. Dogsense
    Dogsense Funster
    May 5, 2014
    420
    112
    Leicestershire
    I plugged a phone charger in the cigar lighter wich worked then in the power socket and not working.
    Used the horn fuse (also 15A) instead of the socket fuse - not working. Put the socket fuse in the Horn - working. So not a fuse fault.
    Need to get a Multi Meter. Any recommendations?
  11. Dogsense
    Dogsense Funster
    May 5, 2014
    420
    112
    Leicestershire
    Yes I checked the F14 fuse wich according the manual is the power socket fuse.
  12. TheCaller
    TheCaller Funster
    Sep 23, 2013
    1,960
    2,333
    Lincs
    Don't rely too much on the manual. The fuses for my two dash sockets are the opposite way round to what the manual says.
    • Thanks Thanks x 1
  13. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,234
    3,656
    walthamstow east london
    always check with a meter what are you plugging in are you sure its not that thats failed
    • Thanks Thanks x 1
  14. Dogsense
    Dogsense Funster
    May 5, 2014
    420
    112
    Leicestershire
    TheCaller, you been right, the two sockets, on my cab are opposite from what the manual says. The 10A fuse for the Cigar Lighter was the faulty one. Problem solved.
    Thanks all for the advice.
    • Like it Like it x 1
  15. peter marshall
    peter marshall
    Mar 5, 2009
    2,702
    1,701
    Well done you guys. :party3::party3::party3::party3:
  16. Bill_OR
    Bill_OR Funster
    Dec 11, 2011
    519
    709
    Nr Hastings, East Sussex
    I know this is an old post but I blew the fuse on one of the 12v sockets in the cab today and the advice about not relying on a visual inspection of the fuse saved me countless hours of faffing around looking for another cause. I put my meter across the fuse and lo and behold it HAD blown even though it looked fine.
    Thank you!!
