12v Battery Protection From Ciggie Lighter Anyone
Discussion in 'Motorhome Chat' started by Nirvanauk, Jul 14, 2015.
  1. Nirvanauk
    Nirvanauk Funster
    May 8, 2011
    1,399
    7,360
    God's county. North Yorkshire.
    the cigarette lighter in my car is on all the time and I want to run a portable cool box from it. Trouble is that after an hour or so the battery will be flat. Many years ago I had an adapter that went between the socket and the cool box that would disconnect it if the battery was starting to go down a bit.
    Does anyone know where I can get one of these gadgets from and what would they be called?
  2. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,544
    7,828
  3. Nirvanauk
    Nirvanauk Funster
    May 8, 2011
    1,399
    7,360
    @tonka . Many thanks for that, looks like the one.
    Cheers.
  4. Feltwell
    Feltwell Funster
    Aug 27, 2014
    400
    380
    Shropshire
    I've got one - it's rubbish!
    We have a Ford S-Max people carrier that has a stupidly small battery, we always had to be careful about the courtesy lights flattening it whilst we were packing up after camping holidays, to the extent where I ended up always taking jump leads on holiday with us!
    I bought one of these to plug into the coolbox as I was worried about that flattening the battery during stops on our journeys. However, I simply found that every time I turned the engine off it cut the power to the coolbox immediately, regardless of the state of battery charge.
    • Like Like x 1
  5. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,075
    2,920
    Kendal, Cumbria
    I'd rather hope that it would. There's a good chance that if it waited to see 11.6v before turning off the vehicle wouldn't start anyway. Ideally you only want the cool box to be connected when the engine's running.
    • Like Like x 1
  6. Feltwell
    Feltwell Funster
    Aug 27, 2014
    400
    380
    Shropshire
    I'd had the coolbox left on (unintentionally) with the engine off for about 45 minutes before and the car showed no hesitation in starting. It just seemed that this bit of kit is a bit too quick to knock the power off.
  7. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,911
    17,579
    YO11 2BD
    That is 11.6v under load from the cooler.
    a few seconds after disconnecting the cooler the battery voltage will have recovered sufficiantly to start the engine.
    your engine battery can show as low as 9v while under cranking loads but soon recovers to 12.6v
    • Like Like x 1
  8. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,397
    2,661
    Surrey
    What is the make and model of your car? There may be a simpler solution.
  9. Nirvanauk
    Nirvanauk Funster
    May 8, 2011
    1,399
    7,360
    @DanielFord it a 2010 skoda Fabia. The local dealer says it can't be changed (?)
  10. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,397
    2,661
    Surrey
    Damn, not a make I am familiar with. It is worth noting that most manufacturers have the wiring for both set ups. If you dismantle the assembly, you may well find, behind the 12v socket, there is a redundant spade joint. This will be the switched live, so you unplug the permanent live from the socke and plug the other one in, hey presto, a switched 12v socket.
    • Like Like x 1
