Terry
Hi does anyone make or have such a device ?
terry
terry
If you look to pay from £80 to £200 you will get a compressor that can be permanently mounted inside a locker with an outlet (or two) fixed conveniently on the body ready for you to connect the tyre inflator. If you have air-ride suspension, you can connect it via valves to that, too. I have a heavy duty one that was once supplied to operate air-operated diff locks for a Land Rover.
to be honest what you need is a tank somewhere on the van .if you do repair your tyre you may need that big whoosh of air to push out the beads.
The way around this Alan is to place a rope around the tyre and tie it off as a Spanish turnkey, as the rope is tightened the walls of the tyre are pushed out onto the rim,
Doug...
hi doug not always on radials now you use a sausage that you slip over the edge of the wheel. it can be done using a cycle tube to take up the gap .an.
My other half won't let me out to playalot of off road boys look for the ones off ambulances . we see lots when playing in the winter.you,ll have to come and play with us in the sun. ha ha .but you will need a few tubes and patches . blinking thorns grow in the sand and penetrate tyres all the time. cheers alan.
That looks a nice bit of kit :thumb: I shall put it in my memory bank along side some others until I drop on one :thumb:I have a five quider from netto in the van just in case the air suspension does not go up never had to use it but like a lot of other stuff I carry in the van ( a load of crap ) you never knowHigh Terry
Bought a fantastic little Bonair pump from Costco just before going on the Italian Job. No probs at 5 bar and reasonably quick. Good coiled hose and a brilliant strong bag for it all to go in. One of the best bits of kit I've bought in a long time.
Good hunting, Cheers Dave.
