12v Adaptor
Discussion in 'Tech/Mech General' started by Gollom, May 26, 2015.
  1. Gollom
    Gollom Funster
    Apr 6, 2014
    206
    122
    Preston, Lancs
    Big Gertie has a Zig MC-2000 control panel with a 12v socket in it. I would like an adaptor that gives me 2 USB (preferably 1 @1A and 1 @ 5A) but the plug on the standard car adaptor I have is too "fat"
    Look as I may I cannot find what I want on ebay (or wherever) I am sure someone much wiser than me will shake their head, sigh and promptly post a link to the very thing I want (y)
    Well, I like to hope so!
  2. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,388
    3,157
    Kendal, Cumbria
    • Like it Like it x 1
  3. rickwiggans
    rickwiggans Funster
    Apr 2, 2014
    79
    56
    Lancashire
    The socket you have is probably a DIN socket, similar, but, as you have noted, smaller than a traditional cigarette lighter socket. You can get a an adapter from this to the standard "fat" socket, (most motorhome dealers stock them)then use USB adapters in that.
  4. Mr B
    Mr B Funster
    Feb 1, 2015
    401
    993
    yorkshire
  5. Gollom
    Gollom Funster
    Apr 6, 2014
    206
    122
    Preston, Lancs
    Looks like what I need thanks as I have a USB adaptor already. Just one question as the blurb says the following. Will it still be safe to use?
    Note: this adaptor does not change the voltage at all, you must make sure the equipment you use on it is rated at the correct voltage for the socket you are using.
  6. Gollom
    Gollom Funster
    Apr 6, 2014
    206
    122
    Preston, Lancs
    So is a DIN socket the same as a HELLA socket?
  7. jockaneezer
    jockaneezer Funster
    Dec 12, 2010
    1,825
    3,485
    Cumbria
    Yup !
  8. BwB
    BwB Funster Life Member
    Apr 3, 2011
    613
    567
    Suffolk UK
    I thought 2.1A was the maximum per USB socket?
  9. rickwiggans
    rickwiggans Funster
    Apr 2, 2014
    79
    56
    Lancashire
    I don't think the above is what you want.That is DIN plug to double DIN socket. From what you say, you need something like this:http://www.amazon.co.uk/Rocket-Radio-Standard-Lighter-Adaptor/dp/B0042EYTEI
    DIN to standard cig lighter. Then the commonly available USB adapters that pug in to a standard cig lighter will fit.Like this:
    http://www.ebay.co.uk/itm/NEW-Griff...er-/261726571540?_trksid=p2141725.m3641.l6368
    I've never seen a USB adapter that fits a DIN socket - although they may well exist.
  10. Gollom
    Gollom Funster
    Apr 6, 2014
    206
    122
    Preston, Lancs
    Spot on - thanks.
    Supplementary question - how much power does a 2.1A USB socket take? It;s the one I'd need to charge my tablet which has a 6300 mHa battery
  11. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    2.1 amp max actually you asked how much power so 2.1 x 12V = 25.2 Watts
    Watts being the SI unit of power.
  12. ES Cumbrian
    ES Cumbrian Funster
    Oct 10, 2014
    226
    90
    Cumbria
    2.1 amp is the maximum power for the USB side so at 5 volt(usb) X 2.1 amp - 10.5 watts (max) loose a bit of efficiently between the 12volt and the 5v USB and you will be using less than 1amp at 12volt for a single usb
  13. Gollom
    Gollom Funster
    Apr 6, 2014
    206
    122
    Preston, Lancs
    Sorry, should have been clearer. Is that a lot of power to take or not too much? I.E. if I charged my tablet twice would that seriously deplete the leisure battery? Not looking for exact science, just a general "feel"
  14. ES Cumbrian
    ES Cumbrian Funster
    Oct 10, 2014
    226
    90
    Cumbria
    Look at it from the battery point of view, your tablet battery is 6.3 A/H your leisure battery will be something like 90 A/H so a couple of charges isn't going to run it flat but it will add to all the other things you use your battery for.
