12mm push fit water connector availability (1 Viewer)
Oct 26, 2014
1,844
3,173
Dumfries and Galloway
Pilote P696GJ
I have a leaking tap which is dripping so badly I've had to switch of the pump .
It can't be fixed so I going to isolate does anyone know if these connectors are available in spain
Geejay
300
237
Scottish Borders
Van Conversion
since 2007
I think some Accesorios para Autocaravanas depots will have something. Here's one, but depends where you are, or maybe you can get it posted: scroll down and there's 2 Tapons http://www.masquecamper.com/categorias/Agua-y-sanitarios/Instalacion-rapida-John-Guest/
If not, detach the pipe, fold it over to make a tight bend and bind it with string to stop the water. You'll need to replace the pipe eventually. Alternatively, if you can get a straight connector and a bit of sacrificial pipe to stick on the end, then do the same.
Neil S
Oct 26, 2014
1,844
3,173
Pilote P696GJ
Thank you for your reply , I managed to source a 12mm straight connector from a Motorhome repair shop in Benicarlo which has allowed me to bypass the bathroom sink and still have the shower in use . (y)(y)
