12mm Infill Strip. Tips on fitting please.
Discussion in 'The Beginner' started by emmitdb, Mar 7, 2016.
  1. emmitdb
    emmitdb Funster
    Aug 14, 2009
    1,806
    1,671
    Cornwall
    Hi All,
    I've posted here because I couldn't find anywhere else.
    When we bought the 'Van one of the things we noticed was that the infill 'rubbing' type strip found at the bottom of the outside walls (before it joins the bottom sill) had shrunk so that there was a gap at either end of each run.
    I've bit the bullet and bought the strip to replace them but would appreciate any tips on how to replace them. There are no End Caps so it can't be slid in.
    Over to you.
  2. DP_JAY
    DP_JAY Funster Life Member
    Mar 17, 2010
    1,804
    1,027
    Cark, Cumbria
    • Useful Useful x 3
  3. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,521
    9,942
    a bucket of hot water to warm and soften the strip before installing will really help
    • Informative Informative x 2
    • Like Like x 1
    • Useful Useful x 1
  4. gus-lopez
    gus-lopez Funster
    Aug 18, 2014
    5,088
    9,705
    Lorca,Murcia,Spain
    Hot air gun or hair dryer & side of a small flat screwdriver to push it in.
  5. emmitdb
    emmitdb Funster
    Aug 14, 2009
    1,806
    1,671
    Cornwall
    Can't remember the last time I had a hair drier in my hand.
    Me? bald as a coot.
  6. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,909
    17,578
    YO11 2BD
    There is a special spreader tool which opens the sides and inserts the trim as you draw it along the bead.
    Commonly used for old style rubber surrounded windscreen trim.
  7. emmitdb
    emmitdb Funster
    Aug 14, 2009
    1,806
    1,671
    Cornwall
    Don't see that one working Papa. We're talking aluminium sides, not flexible rubber.
  8. Pikeman
    Pikeman Funster
    Nov 6, 2011
    285
    318
    Worthing
    So what is the strip made of? Is it a PVC, rubber or Alli? I'm confused.
    Keith
  9. pappajohn
    Aug 26, 2007
    29,909
    17,578
    YO11 2BD
    My apologies.
    But im sure there is a similar tool that 'folds' the trim insert and presses it in to insert it then it springs back naturally.
  10. emmitdb
    emmitdb Funster
    Aug 14, 2009
    1,806
    1,671
    Cornwall
    Watch the Vid. Keith.
    The flexible strip in my case isn't around the door. It is, if you like, similar to that found in the awning skirt on a caravan. It's cosmetic in my case, (I think) but on a acaravan it hides the screws that hold the awning strips to the side of the caravan.
    Regards
  11. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,074
    2,920
    Kendal, Cumbria
    Once you have it in force as much length in as possible then cut it an inch too long. Leave it for as long as possible (at least a week) before finally trimming to correct length. It tends to shrink a little once fitted - probably because it gets stretched when fitting. I just use a blunt screwdriver or a knife from the cutlery tray to fit it.
    • Useful Useful x 1
  12. bertiebasset
    bertiebasset Funster
    Jun 16, 2014
    299
    290
    NOTTINGHAM
    I replaced all mine last year. That was 4 lockers and door trims as the stuff that was in had shrunk and also gone very sticky for some reason. I waited for a hot day and pushed it in with thumbnail. It takes time and your thumbs will be sore afterwards but using a metal object may damage the aluminium channel. I eventually finished mine off in Spain and it was much easier being in the 30's. As previously stated, leave as long as possible and try to push too much in as it will shrink.
