12 Volt System On A 1997 Swift Sundace
Discussion in 'Motorhome Chat' started by G1YDQ, Apr 24, 2015.
  1. G1YDQ
    G1YDQ Read Only Funster
    Oct 24, 2014
    50
    27
    Polperro
    Hello All,
    Denise and myself are currently away in our van in WGC Herts. We left home last Tuesday for a week away.
    All seems fine whilst on the hook up with the 12v & 240v electric system. now, we run a " cool box " from the 12v socket below the electric control panel, all is fine, be it connected to the hook up or not. The problem seems to be, once we start the engine the 12v side of the van seems to become disabled. In other words, the cool box receives no power, also the internal lights don't work. Turn the engine off and 12v power is restored, not a lot of good if we are on the move. I can get the cool box to work via the 12v socket on the dash, but this means running a lead into the front of the van. I have tried switching the switch on the control panel between leisure battery and van battery and this makes no difference, the 12v side remains " dead " till the engine is turned off.
    Your thoughts would be much appreciated,
    Kind Regards,
    John & Denise.
  2. gloworm
    gloworm Funster
    Dec 30, 2008
    930
    1,753
    Cheshire
    Hi John & Denise,
    the good news is your motorhome is fine, This is normal on uk motorhomes, your best option is to wire a plug direct to your leasure battery, Enjoy your break.
    Eric
  3. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,910
    6,818
    West Sussex
    Habitation electrics being turned off with the engine running is standard in British built vans, a hangover from caravans and required for NCC compliance.
    There will be a relay some ware could be inside or external to the charger unit that controls it, find it disconnect the coil problem solved, do check everything else works as it should once done.
  4. G1YDQ
    Oct 24, 2014
    50
    27
    Polperro
    thanks Lenny
  5. G1YDQ
    Oct 24, 2014
    50
    27
    Polperro
    Well, thank you "lads" that seems to have put the problem to bed, can now get on with our "break" Mad, we have had the van 18 months and never noticed it before, mind we have not used the van much till I recently retired. Should be more observant.
    Kind regards,
    John.
