12 volt cigarette type plug
Discussion in 'The Beginner' started by Malcolmwake, Jul 10, 2012.
  1. Malcolmwake
    Malcolmwake Read Only Funster
    Apr 14, 2012
    3
    Forfar
    I am wanting to use a whale submersible pump with a portable water carrier to fill my onboard water tank for those occasions when I am not near a convenient water tap. I am struggling to wire up the 12volt cigarette type plug. It is not like a 13 amp type plug and after preparing the necessary live/neutral wires I think that I will have to solder them to the blades inside the plug as there are no screws etc to attach them to. I do not think that crimping them to the blades will be secure enough.
    Help please.
  2. hilldweller
    Dec 5, 2008
    27,518
    26,615
    Macclesfield
    There are many differing plugs, a good photo would help us help you.
    • Like it Like it x 1
  3. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,187
    15,162
    Leeds the one up North
    +ve -ve
    Crimps are quite secure if the correct size and the right crimping tool are used. A photograph of the terminals would be useful.
    EDIT Brian is faster lol
  4. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    Do you have a problem soldering?
  5. upmarkethippy
    upmarkethippy Read Only Funster
    Feb 25, 2008
    364
    81
    Hull
    no ends for your wires!
    Hi,
    I would imagine the spade connectors you have on your 12 volt socket will require a pair of 'female spade connectors' to complete the job...
    Like these http://www.ebay.co.uk/itm/100-6-3mm...5?pt=UK_In_Car_Technology&hash=item3cb39cc0d5
    you will then need to 'crimp' the connector onto the wire.
    Just wondering, have you fitted a fuse in the positive side of the wireing.....better safe than sorry......
    If you need any more assistance please do ask....
    07926 154457
    Cheyne
  6. Techno
    Jul 28, 2010
    14,187
    15,162
  7. Malcolmwake
    Apr 14, 2012
    3
    Forfar
    Thanks for replies.
    The plug is the type that would fit into the cigarette lighter and /or the van's 12 volt sockets. One screw secured both halves of the plug. Inside the plug there is the pin for the live feed and the other part is the 'wings' for the neutral wire. The plug and the wings merely have a flat blade or spade for the wires to rest on and I think that I will have to buy a soldering iron or a crimping tool to make secure connections.
  8. Techno
    Jul 28, 2010
    14,187
    15,162
    Most likely not enough room in the plug to accommodate crimps. Be sure to solder the parts while not in contact with the plastic housing
  9. upmarkethippy
    Feb 25, 2008
    364
    81
    Hull
  10. Malcolmwake
    Apr 14, 2012
    3
    Forfar
    I have not used a soldering iron before but my best bet I think would be to buy or borrow one and solder the wires on to the blades.
  11. Techno
    Jul 28, 2010
    14,187
    15,162
    Excuse the accent
    [ame]http://www.youtube.com/watch?v=BLfXXRfRIzY[/ame]
  12. Techno
    Jul 28, 2010
    14,187
    15,162
  13. icantremember
    icantremember Funster
    Sep 2, 2010
    5,390
    7,494
    Nr Watton in Norfolk
