12 v sockets
Discussion in 'Motorhome Chat' started by ShiftZZ, Sep 26, 2011.
  1. ShiftZZ
    ShiftZZ Funster Life Member
    Feb 19, 2008
    19,812
    36,113
    Leicestershire
    Just looked at a new(er) van and I see it has those 'smaller' 12 sockets , I think they are called Dim (or that could just be me). Is it possible to have these changed? I would ratehr not buy some of those smaller adaptors.
    Just wondering.
  2. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    must be easier and cheaper to change plugs rather than sockets.:thumb:
    • Like Like x 1
  3. dennismartin
    dennismartin Read Only Funster
    Jul 26, 2011
    135
    19
    hull
    i changed mine
    • Like Like x 1
  4. JJ
    JJ Funster
    May 1, 2008
    14,748
    26,330
    The 1987 Hymer I have has both types of sockets so I use adaptors when needed...
    In the (self build) Wagon I have "normal" sockets and some small sized (higher amp) ones but the latter are still in the bag waiting for the fitter to get around to wiring them in...
    To go from small to big should be ok (remove socket and make the hole bigger) but more tricky (I guess) the other way around... :Wink:
    JJ :Cool:
    • Like Like x 1
  5. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,231
    16,828
    Liverpool.
    IMO stay with the din sockets and change the plugs. The din sockets are far less trouble and last much longer. Never did like cigarette lighter plugs. The din plugs are far better made and have a better contact as the contacts are normally brass or copper. Also its easier to change a plug than a socket.
    If the van has din sockets fitted they are normally a higher amperage than the cigarette type.
    • Like Like x 1
  6. darklord
    darklord Read Only Funster
    Apr 28, 2011
    1,241
    1,243
    essex
  7. haganap
    haganap Funster Life Member
    Dec 5, 2007
    11,153
    13,979
    Heavan
    to answer your question Dave, yes they can be changed and its straightforward, even an NHS nurse could do it :Wink: Olearys stock the UK socket. as said you could just buy an adaptor but thats too easy. :thumb:
  8. JJ
    JJ Funster
    May 1, 2008
    14,748
    26,330
    Another thing I use is this type of 12 volt plugs...
    They fit in ether type of socket...
    Bet you knew about them already though...:thumb:
    JJ :Cool:
  9. Snowbird
    Apr 24, 2009
    10,231
    16,828
    Liverpool.
    Yep !!!
  10. JJ
    JJ Funster
    May 1, 2008
    14,748
    26,330
    Clever clogs...:Rofl1:
    JJ :Cool:
    • Like Like x 1
