10amps hook up
Discussion in 'The Beginner' started by jgee, Mar 11, 2010.
  1. jgee
    jgee Read Only Funster
    Dec 21, 2009
    85
    wigan
    many sites have 10amp hook up supply has a rough guide what appliances can i expect to use and keep within limits to prevent overload:Smile:
  2. scotjimland
    Jul 25, 2007
    28,936
    25,624
    10amps gives you 2.3 kw or 2,300 watts
    so in theory you could run a 2kw fan heater, a kettle , or toaster etc but obviously not all at once, check each appliance's label to see what it's rated at.
    also remember you have to allow about 3 or 4 amp for the battery charger and fridge.. which only leaves 6 - 7 amps or about 1.5kw
    The easiest way to monitor is to fit an Owl Wireless Power meter , about £30 from many DIY stores, this gives you an accurate readout of your power use.. it has an alarm that can be adjusted to suite the available supply.
