100watt folding solar panel
Discussion in 'The Beginner' started by jgee, May 15, 2012.
  1. jgee
    jgee Read Only Funster
    Dec 21, 2009
    85
    wigan
    can anyone recommend a company where i can purchase 100watt folding solar panel seen several on ebay etc but would always buy of recommendations 'lenson' has been mentioned
  2. Phill D
    Phill D Read Only Funster
    Dec 6, 2011
    4,414
    4,633
    South Wales
  3. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,737
    5,967
    Mansfield,Notts
    I have said on other posts the £ asked for folding panels is way over their worth if your capable of screwing a hinge on a door you can build your own and save 60% ie a £300 panel for approx £130. Well worth the hr or two it will take
    As for return on outlay it will never happen
    You are buying reliability and conveniance:thumb:
    That in itself is often worth more than the product
    Geo
    • Like Like x 2
  4. hilldweller
    Dec 5, 2008
    27,253
    26,254
    Macclesfield
    Depends how you use you van, if you regularly are on hook up and/or never stop for more than 3/4 days you don't need solar.
    If you wild camp for days on end it's solar or generator and generator is the only reliable one on an annual basis.
  5. Phill D
    Dec 6, 2011
    4,414
    4,633
    South Wales
    thanks again for the input, we rarely stoped anywhere more than 4 days so far in the past 5 years since we have had a motorhome. plus have gone 4 days easily on our GEL battery without a problem even in the past month when perhaps we may use a bit more power than in the summer months.
    i guess for us then it stays on hold... for now:thumb:
  6. magicsurfbus
    magicsurfbus Funster
    Oct 11, 2010
    3,734
    8,822
    NW England
    It could be argued that someone who travels abroad and has used campsites in summer for electric hookups, then is able to switch to Aires or very basic field plus tap sites with a solar panel may eventually recoup a goodly portion of the cost of the panel, but it would take a while.
    I wouldn't go for a folding panel myself - you should pay less for the equivalent wattage fixed panel then you wouldn't have to worry about setting it up securely at every stop.
