beltsandbraces
you would think it should be a matter of course, once installed filled up, tested and cost put on instalment.
What @Jaws said. Unfortunately many people aren't in the position of being able to do many things themselves , which makes it far worse when you are paying someone who then don't do what you are paying for.Or worse, lazy !
One of the reasons I do all my own work is I simply do not trust other people ...
My list of trusted people to work on my van is very very short.
So who would change the Calor gas bottles? That is just as dangerous as fitting Gaslow or GasitSo summing up then - there are 'expert' cowboys out there who are able to 'self certify' their work to satisfy insurers.
Surely this cant be right.
When we had our narrowboat built, which falls into a very similar leisure industry sector i.e. many privately owned, many hired out, gas installation work had to be installed and certified by what was then called a Corgi Registered Installer. Many boat fitters abandoned gas work because for them to get and keep the 'gas ticket' cost them a lot of money. Consequently the number of gas fitters on the canal system diminished significantly.
Without the gas certification, you couldn't obtain a boat safety certificate which in turn, meant you couldn't register the vessel with British Waterways (now Canal & River Trust), hence you couldn't get a boat licence, insurance or mooring permit - so technically you couldn't use the boat.
Its time the Motorhome/Caravan Industry was brought in line IMO.
Equally there are no regulations for using gas in marine boats.
It all seems to come down to testing, if the fitter has no means of filling the system how can he test it??
They either need to start stocking gas, or take the vehicle to a LPG sales point to prove it works before letting it out of their site, or presenting their bill
Gaslow sell the correct equipment to allow their equipment to be pressure tested safely" if the fitter has no means of filling the system how can he test it??"
Perhaps suppliers of the systems could rent out a filler adapter which had a schrader-type valve to allow pressurising by a foot pump to allow leak detection?
I was replying to your statement about certification.Changing Calor gas bottles over is no more dangerous than filling a car with petrol, providing common sense is used.
I was asked by comfort for certificates, for a self build I did...None of the insurers I've used for a MH have ever asked for or been sent any kind of installation or test certificate for the LPG
Because the general public would then be prohibited from changing their own gas bottlesSome points that come to mind from reading this...
If the vehicle is for hire then there are obviously some safety checks that have to be made (from reading the points above but I wasn't aware ) and certified for the van to be hire out. ..why can the same checks not be part of any motor home gas installation? ?? And apply to all..
The Gaslow test equipment is really inexpensive and goes straight into the external fill point so the whole thing is testedReference is been made of pressure testing etc,but it's important to remember that the only time and way to test the filling system up to the inlet of the cylinders or tank is to actually have it connected up to the fillIing pump.. as there will be a non return on the fill.. so the test on the rest of the installation won't show up a leak there...
Entirely reasonableif you've paid someone to do it its reasonable to expect they have done that...
Andy
So does that mean that the people who hire the said motor homes can't change their cylinders when they are on the road???Because the general public would then be prohibited from changing their own gas bottles
The link just takes you to the Gaslow page@eddievanbitz
Is this the gaslow test equipment that you're referring to?
Wish I'd known about it when I did mine! Could have split the cost with my neighbour who fitted his own system too. I think for piece of mind if fitting your own system it's worth the cost.
Hi I have no idea what the arrangements are for hire vans? All I know is that for gas installation when the van is for hire and reward additional gas checks have to be carried out. If those checks were extended to cover motorhomes used privately you would get to the point where, we, for example wouldn't be allowed to swap an empty calor gas bottle over, for an Old lady, but she would be allowed to do it herselfSo does that mean that the people who hire the said motor homes can't change their cylinders when they are on the road???
I saw your bit about equipment been available to test the whole system... I wasn't aware it was available but not surprised you say it's expensive....
Thanks Andy.
HmmThe link just takes you to the Gaslow page
