o/p here
Ive just gone to check the battery as discribed above, Ive got two batteries, I pulled fuse on the first one and it has melted and blown, I checked the ampage draw on the PANNEL it had changed to .4amp and th voltagwe had gone ujp to 12.6 (was 12.4 with blow fuse in ) I replaced the blown fuse with correct size, I checked the pannel again the ampage draw is now steady at .3amp (which seems to be in line with other scout owners).
I put the charger on whist I type this, what next pepole?
Doesn't make sense, then should be any difference between a blown fuse and no fuse at all.
I would recommend removing the fuse again and measuring the voltage on each battery while they are isolated from each other.
Connecting two batteries together that are at differnt stages of discharge can lead to very high currents indeed.
Gordon
