engine size ? (1 Viewer)
RS SPIKE
192
29
derbyshire
ELDDIS SUNSTYLE 140
newbie
can anybody advise me what size engine I would need to tow 1500kg comfortably ?
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
I think you need to check the vehicle plate to see what it is allowed to tow.
My 4250kg van is only permitted 1250kg on tow.
My 3 litre engine could handle well over that
23,836
72,457
My Chieftain is rated at 5.25t, we had it fully loaded and was towing 1.2t
The 2.3 litre Fiat engine more than coped, sadly the bloody gearbox did not !!!!
43,320
49,406
My lawn tractor has a 480cc V twin petrol engine and is capable of towing a 2.25t landrover on evel ground.
Doesnt really answer your question but a 2.5ltr engine is capable of towing a lot more than 1500kg.
As already said, the more important issue is your vans train weight (maximum combined weight of van and loaded trailer)
the trailers fully loaded weight is applicable....even if towed empty.....so a 1500kg trailer may only have a true payload of around 1100kg/1200kg
If your actual load is 1500kg you will need a trailer with a gross weight of around 1800kg/2000kg
RS SPIKE
RS SPIKE
192
29
derbyshire
ELDDIS SUNSTYLE 140
newbie
I know it is a mine field just looking at buying our first motorhome.
I have a trailer which is 490kg and a car at 950kg which totals around 1500kg.
just trying to guage which engine I require before I look into train weights
Nov 3, 2013
3,170
9,374
Portugal
Fiat Ducato Auto Wildax
C/van since '73 .M/h.2009
Hi.
Modern engines really are top notch,however,old school me..... There is no substitute for power,what will pull a lot,will pull a little,buy the biggest you can and enjoy cruising up hills as if they are not there. Look on the cabs of lorries,"480",once top mill is old hat,there are 500 pluses out there. Fuel ?,the bigger lump will hold a higher gear longer,so swings and roundabouts.
Have fun,just because you may have the power,you do NOT have to leave black lines on the road when pulling away from traffic lights.Tyres cost money and unlike skin,cannot repair themselves tread wise.
Tea Bag
mjltigger
1,619
2,672
Trowbridge
Autotrail Dakota Max
Bigger engine doing less work will use less fuel than a little engine pulling its heart out. Having g said that you can tow a jumbo jet with a 2 litre engine as long as you have the right gear ratio and a decent clutch.
